Block heater question
Joe Fleury
11-15-2004 17:29:15
hi, I'm new to this site but I really enjoy it!
I check in every day to see what's new.
Anwyway, I have a 1945 W4 McCormic Deering..I live in Nova Scotia (Canada)where it can get very cold sometimes and i have a hard time getting the red tractor going! Is there any way that I can hook up a block heater? Your help is appreciated!!! -Joe, NS
Bob
11-16-2004 06:21:12
 Re: Block heater question in reply to Joe Fleury, 11-15-2004 17:29:15
For applications, or a dealer near you, call:
Phillips & Temro Industries Ltd. 100 Paquin Road Winnipeg, Manitoba, R2J 3V4 Phone: 204 667 2260 Fax: 204 667 2041
El Toro
11-16-2004 05:09:58
Hi Joe, If you have a problem finding a block heater give Phillips & Temro in MN a call at 1-800-328-6108. They also have heaters that you install in the radiator hose. Hal
jb2
11-15-2004 19:46:11
Hi Joe, Canadian Tire used to sell an 800W heater that went into the lower rad hose. It looks much like a frost plug heater but it is installed by cutting a hole in the lower rad hose. The element has to be as close to the block as possible. They work very well, used one on B414D for many years.
Good luck
JB2
Hugh MacKay
11-15-2004 19:07:06
Joe: Your right, you will not find a TSC store in Atlantic Canada. It's just a farm and country hardware store. You might try Princess Auto in Dartmouth or one of the Co-op hardware stores.
My brother has another type, kind of like a blanket designed to fit tightly on bottom side of oil pan of his 230. I never asked him much about it but it must be designed for a tractor as it fits snugly around pan right up to block. If you wish e mail me, I'll give you his phone no. He is in central NS.
Michael Soldan
11-15-2004 18:19:55
Joe, I was given a magnetic block heater as a gift from my kids. You can stick it on the oil pan, side of the block, at the water pump housing, where ever you want to heat...TSC stores carry them and they were not expensive. When you are ready to go unplug it and set it on the bench for next time. I use mine on the bottom of the oil pan on a small diesel to heat it up when the temperatures get below -10C, I can start with a shot of ether above-10C. They are pretty nifty and easy to use....Mike in Exeter Ontario
Joe Fleury
11-15-2004 18:23:50
 Re: Block heater question in reply to Michael Soldan, 11-15-2004 18:19:55
Thank you so much! I'll shop around...not sure about one of those stores around here but oh well. Thanks again
-Joe
parts man
11-15-2004 19:33:41
 Re: Block heater question in reply to Joe Fleury, 11-15-2004 18:23:50
we have a W4 that came from western Canada. It has a heater that replaces one of the head studs. I suppose the bottom end goes right down into the coolant, and the top end is torqued down on the head. I wouldn't have any idea where you would find one of those now!! Has anyone seen one of those before?? Were they availlable from the dealers when the Ws were new?? Thanks all!!
steveormary
11-15-2004 20:38:29
 Re: Block heater question in reply to parts man, 11-15-2004 19:33:41
Joe;
We preferd an external tank heater. Had a head bolt heater on an M. Lower rad.heater on the Ferguson. External tank heaters on the 706 and the other M.They connect to the block drain for supply and feed into a tap in the head or water pump. Least liked was the magnetic heater. Didnt think it did a very good job.
steveormary
