Super C grille screen material
Ken M
11-15-2004 17:49:58
Does anyone sell the screen material that goes in the grille on a super C? It was spot welded in. How do I attach a new piece (if it is available)?
BIG JOHN
11-16-2004 18:01:15
 Re: Super C grille screen material in reply to Ken M, 11-15-2004 17:49:58
I use the Hardware Store varity (Hail Screen, Hardware Cloth)and have a masonry/stone 3" wide chizzle that works just fine to form the screen around the ribs. Then I use a pair of 3" clamping type vice grips to hold it in place while JB Weld cures to hold the screen in place on the ribs.
P.S. No one has ever noticed the screen is not the orginal size.
gene b
11-16-2004 03:36:05
MARKS TRACTORS has it for 14.00 per tractor. The trick is bending and making the little clips that go over the bars. Some use a rubber cement that is used for fastening windsheilds and it works good. I would like to find that ACE store as 1/8 and 1/4 is common but you need the 3/16 stuff.
Farmer Bob
11-15-2004 21:03:01
Ken, If you are looking for the original screen that has 5 squares per inch, I sell it by the square yd. Email me for more info. If you want the hardware store variety, follow the advice below.
donwisc
11-15-2004 20:19:03
Go to ACE hardware they have screening close enough to original. Usually kept at the service desk and is about 2.00 a foot.
Nebraska Cowman
11-15-2004 18:02:22
I use "hail screen" used to be able to get it at hardware stores. I find enough at farm sales i never have to buy new.
