Order Farmall Cub Parts Online
Mounting dozer on Ih cub
ihfan2
11-15-2004 19:40:20
I have a 1971 Ih cub and want to mount a dozer on it. Dad bought one at auction and its Ih so it should fit, but I wondered if anyone had any pictures to give me an idea. Thanks, Jake
Farmer Bob
11-15-2004 20:52:39
 Re: Mounting dozer on Ih cub in reply to ihfan2, 11-15-2004 19:40:20
third party image
Here's a pic of a 54A blade mounted on my '64 Cub. Should be pretty close to your setup.
Andy Martin
11-16-2004 05:36:42
 Re: Mounting dozer on Ih cub in reply to Farmer Bob, 11-15-2004 20:52:39
You can also flip the drawbar around and mount it on the front of the axle housings. then the blade pivot will mount on the drawbar and you have a mid-mounted blade which is great for fine finish grading.
I use my Cub-mounted blade regularly. With the hydraulic lift it is a great tool for spreading dump truck loads of top soil.
It's a little light for grading driveways but will smooth loose grave very well.
ihfan2
11-15-2004 20:26:56
 Re: Mounting dozer on Ih cub in reply to John *.?-!.* cub owner, 11-15-2004 20:04:25
I"ll try those, thanks a bunch
