h lift
r koronka
11-16-2004 14:56:37
the hydrolics on my h seems weak. a digger will lift and sodoes my brushhog but the digger when it is 3-4 ft in the ground will hardly come out of the ground. The brushhog will only lift about 3 ft. It has new oil in it. Any answers?
gene b
11-17-2004 03:18:53
 Re: h lift in reply to r koronka, 11-16-2004 14:56:37
Go to a bigger dia cycl and you will get much more power for lifting.
riverbend
11-16-2004 15:24:10
Hook up a pressure gauge and see what you get. If you are seeing 800 psi, that's about it, as long as you have plenty of oil.
What kind of digger are you using ?
