1466 breather
686
11-16-2004 19:05:33
is it possible to make a dt436 with a breather mounted on the side to one mounted in the valve cover? mine blows out oil. thanx
RAS
11-17-2004 08:33:30
 Re: 1466 breather in reply to 686, 11-16-2004 19:05:33
Yes you can install the top breather set up on you engine, valve cover & two pipes will do it. As i said before when this engine was overhauled it is possible the late serial number rings were installed and if so you must have the top breather set up or it will just push oil out of the side breather. Over the years there were many many changes to the 400 series engines and you really must be careful when you get parts.
Allan in NE
11-16-2004 19:26:20
Just thinkin' out loud here,
You don't 'spose there is something wrong with the oil drainback of your head/cover and it's filling and pushing that oil out?
Just seems odd that it would push oil, especially after you have rebuilt it.
Allan
