Super C plow hookup
Robert Lorencz
11-17-2004 09:51:43
I am looking at buying a Super C with 2 furrow plow that has some missing parts. The front of the plow mounts underneath and what seems to be missing is the arms/shafts/etc that attach to the rear to raise and lower it. Does anyone have any photos they can send me?
Thanks
gene b
11-18-2004 03:16:52
 Re: Super C plow hookup in reply to Robert Lorencz, 11-17-2004 09:51:43
I had one of those plows on a SUPER C and there were several parts that went underneath. also the clamps that hold the u-shaped drawbar are needed. I dont remember the model of the plow but your best bet would be to find an owners manual.If you could go to a dealer he mite still have the parts info and be able to help.
kjm
11-17-2004 19:18:40
Robert,The fast hitch was an option on Supers check the ser.# and look it up on the left of the page.
El Toro
11-17-2004 15:11:03
Hi Robert, Are you sure you have a Super C? They usually have the fasthitch, sometimes referred to as a 2-point. The Super C has 3 rockshafts arms where the C has only two. The Super C has the 123cid engine too.
Some these men have pictures with the plow attached to a Super C. They may post them after seeing your request. Hal
El Toro
11-17-2004 15:10:30
Robert Lorencz
11-18-2004 09:03:46
 Re: Super C plow hookup in reply to El Toro, 11-17-2004 15:10:30
S/N is 141548, casting codes are "X" - making it a 1952 Super C. Has everything a Super should have but does not have Fast Hitch. Once I get the tractor someplace where I can take pictures (like my home!)I will post pictures of the plow so you all can have a better look to see what I might need to make this work!
Tim in NB
11-18-2004 15:44:08
 Re: Super C plow hookup in reply to Robert Lorencz, 11-18-2004 09:03:46
I don't think fast hitch was available on the Super C in 1952. I think the first year for the Super C was 1953. Dad's 52 dosen't have it either.
