Disc brakes on IHC 'H'
John in NE
11-17-2004 09:56:41
I tuned up a 'H' tractor for a co-worker that he had to tow up to my place.Anyway once I got it running,I backed it out of the shop to road test it and it had no brakes at all.The serial # is 391xxx,and it has disc brakes.It has been setting for several years prior to last weekend.I've got a cheap manual but is there anything I should look for to simplify my search? It was quitting time for me when I discovered this,so I put it back in the shed and quit for the night.John.
John in NE
11-18-2004 08:44:10
 Re: Disc brakes on IHC 'H' in reply to John in NE, 11-17-2004 09:56:41
Thanks for the replies.I dove into it and found that the "Ramp and Ball?" assembly was rusted and pitted terrible.I found some replacements for $40.00 so I guess I'll put it back together tonite.John.
DWV
11-17-2004 18:40:17
H 391358 and higher came with IH disc brakes.
Nebraska Cowman
11-17-2004 15:27:51
adjust the brakes up and ride them til they get hot to break the glaze. A complete dissasembly and clean helps too.
BEL@IN
11-17-2004 10:48:03
Sounds as you have a Super H (very desirable tractor)with disc brakes. Disc brakes aren`t as desirable. They need to be cleaned and even new discs or some machine work done to smooth surfaces. Be sure to clean the balls and ramps. Good luck.
rustyfarmall
11-17-2004 11:35:18
 Re: Disc brakes on IHC 'H' in reply to BEL@IN, 11-17-2004 10:48:03
It is a 1953 H, not a super H. The supers started over again at serial #501 and only went to #22xxx. Other than your info is correct.
