Order Farmall Cub Parts Online
Cub RPM
Ernest L. Wagne
11-17-2004 11:27:24
Tried to post to find out how to set motor speed. My 1951 thatI just bought , is not running fast enough at full throttle. Any ideas? Thanks.
Ernie
Ernest L. Wagner
11-17-2004 11:31:15
 Re: Cub RPM in reply to Ernest L. Wagner, 11-17-2004 11:27:24
Duh, guess today isn't my day. Have tried to post three times and messed up all three, I think. Question about my 1951 Cub that I just bought? How do I set the RPM up; so at full throttle it is right? At this time it is not running full throttle, when you put it at full throttle. Thanks,
Ernie
Ernest L. Wagner
11-17-2004 14:37:38
 Re: Cub RPM in reply to Ernest L. Wagner, 11-17-2004 11:31:15
Novel, I had a 1948 Cub before this and I can tell by the sound of the motor , that it isn't opening up.The man I bought it from said the linkage was changed, probably when he painted it. Thanks.
Novel Idea Guy
11-17-2004 14:23:26
First, how do you know it's not coming up to full throttle? Do you have a way to read RPMs? Do you have another Cub to compare to? Or, as I suspect, do you just THINK you're not getting full RPMs? Cubs are VERY quiet.
IF it's really truly not coming up to full throttle, you probably have a bigger problem than just a simple adjustment. There is probably something worn/broken/stretched inside the governor.
REA
11-17-2004 13:19:47
Hi Ernest,
I Believe if you look between the governor and your carburetor, that you will see the linkage rod. There should be a pin held in by a cotter pin at the yoke end. If you remove the two you should be able to turn the threaded linkage rod to increase the throdle. Hope this works.
Bob
Ernest L. Wagner
11-17-2004 14:40:19
 Re: Cub RPM in reply to REA, 11-17-2004 13:19:47
REA, yep, I know that much and I appreciate you telling me. I wasn't sure if that would increase the speed. Problem is ,do you know if it should be shortened or made longer?
Thanks for your reply.
REA
11-17-2004 17:08:18
 Re: Cub RPM in reply to Ernest L. Wagner, 11-17-2004 14:40:19
Hi Ernest,
I would believe that if you made it longer that would be correct. When you have your tractor runing and you push the linkage toward the carburetor it should increase the idle speed.
Bob
Ernest L.Wagner
11-17-2004 19:19:47
 Re: Cub RPM in reply to REA, 11-17-2004 17:08:18
REA, I did that but I think it speeded up, so would I shorten it then? Thanks,
Ernie
