Order Farmall Cub Parts Online
1957 international harvester cub loboy
tom sutton
11-17-2004 15:47:00
I need help! Does this cub have A fan shroud? what r.p.m. is the timing set?I set it At idle aprox.450-500 rpm.At full speed 1800rpm the timing is off by 2 degrees.Is this typical?The eng. is overheating at idle temp.85-90 degrees At full speed the temp.increases to 205-210 degrees.The engine has been overhauled.
John *.?-!.* cub owner
11-17-2004 19:28:45
 Re: 1957 international harvester cub loboy in reply to tom sutton, 11-17-2004 15:47:00
The missing shroud will reduce the air being pulled through the radiator.
BIG JOHN
11-17-2004 17:18:42
Yes the 1957 Cub LoBoy does have a raditor fan shroud. Try splitting the difference on the timing. Really though 2 degrees shouldn't be enough to cause your heating problem.
Tom Sutton
11-18-2004 12:35:43
 Re: 1957 international harvester cub loboy in reply to BIG JOHN, 11-17-2004 17:18:42
Thanks for the imput bus driver.It is a-a-a cub a
Thanks John.
Thanks Big JOHN I'm going to take your advice and set it half way after I make A shroud because I can't find one.
