TD-6 MOTOR
27farmall
11-17-2004 17:53:19
I have a chance to pick up a td-6 crawler for a fair price but it only runs on three when switched to diesel is this a common problem or can it be tuned out or fixed? thanks
Haas
11-18-2004 18:33:04
 Re: TD-6 MOTOR in reply to 27farmall, 11-17-2004 17:53:19
Could be a lot of things as "old" said. However he did not mention the decompression valve. Could be out of adjustment and not closing, or could be stuck or warped. This will prevent getting compression to run on diesel.
old
11-17-2004 18:55:29
Could be a number of problems depending on if it runs on 3 in gas also if it runs on 4 in gas then its probably a bad injector. If it runs on 3 in gas it could be piston, valves, or even head or head gasket.
