OT kw/h meter....in line?
ButchWI
11-18-2004 15:20:01
Wondering if anyone knows of a rather inexpensive in line meter to measure electricity usage? I would like to know how much juice is used to keep a tractor warm when it is plugged in in cold weather. Is there even such a THING?
ButchWI
Ren Tescher
11-18-2004 20:14:18
 Re: OT kw/h meter....in line? in reply to ButchWI, 11-18-2004 15:20:01
A Google search turned up:
Link
Kill a WATT meter for under $40
Ren
dona nobis pacem
Hermit
11-18-2004 18:06:44
Model P4400 "Kill A Watt" Meter. Digital display, measures volts, amps, watts, freq, power factor, cumulative KWH. I think it cost about $25-30. Plugs inline with the unit being checked. Info on company website.
www.p3international.com
Andy Martin
11-18-2004 15:42:26
Best thing I can come up with is one of the sensors used in woodworking to turn on your dust collection system when you start a saw. It is basically a relay that you plug the saw into, when you turn the saw on the current flow ot the saw energizes the relay and that switch is used to start a vacuum. Instead of starting a vacuum, you plug an old 110v clock into it and in the morning you can tell how many hours the heater has been on overnight. KWH computation is elementary from there, ignoring inrush current into the heater you'd be close.
I've been wondering how to do this for years to monitor stock tank heaters. An inline ammeter which will also record KWH is about $1,500 and I don't want to kmow that bad.
With your question, I called an EE and we figured this method out. I think the vacuum triggers are $15 or so. You are supposed to plug each tool in you rshop into one and whichever tool gets energized starts the vacuum.
