primer
Jonathan Mirgon
11-18-2004 16:52:20
what is a good primer to use on my 1940 (a)
Thanks in advance ,
Jonathan Mirgon
JRB IN MAINE
11-18-2004 17:29:14
 Re: primer in reply to Jonathan Mirgon, 11-18-2004 16:52:20
use eching primer if you are covering bare metal then spray sandable primer over after as a sealer . keep from mosture till paint most primers resist moisture for about 36 hours.
JRB IN MAINE
11-18-2004 17:08:16
What are you doing primeing bare metal or just primeing sanded paint ?
Jonathan Mirgon
11-19-2004 08:17:05
 Re: primer in reply to JRB IN MAINE, 11-18-2004 17:08:16
I have taken the tractor apart piece by piece, cleaned each piece down to bare metal, filled any pits and then used a good quailty primer in a spray can on each piece. It is now fully reassembled. I thought it would be best to shoot the whole tractor with a spray gun in primer beffore painting.
JRB IN MAINE
11-19-2004 18:29:12
 Re: primer in reply to Jonathan Mirgon, 11-19-2004 08:17:05
If you do use a good primer sealer wet sand 600 grit paper air and wipe dry couple of times than tack rag off and than paint . best of luck! Jeff
