Block stamped with......
AlbertafarmallA
11-20-2004 22:48:52
I'm pulling apart my 1949 super A and find the prefix FAAM is stamped on the block. I can not find what the "M" stands for????
SAm in NS
11-21-2004 04:35:12
 Re: Block stamped with...... in reply to AlbertafarmallA, 11-20-2004 22:48:52
That's your prefix for your motor serial number. If you look on the left hand seat support plate you should have a serial number tag. The prefix for the number is FAA. The M just indicates that it is the motor serial number. By the way, if you compare your chassis serial number (under the seat) and your motor serial number they probably are not the same. Hope this helps, SAm in NS
AlbertafarmallA
11-21-2004 09:59:35
 Re: Block stamped with...... in reply to SAm in NS, 11-21-2004 04:35:12
Thanks Sam, and by he way, the two numbers don't match. Close but not quite.
SAm in NS
11-21-2004 13:45:05
 Re: Block stamped with...... in reply to AlbertafarmallA, 11-21-2004 09:59:35
The earlier the tractor the more likely they are to match. I believe that when they used the same motors in power units and on balers etc. they continued in the same serial number sequence. The net result being after a while they don't match any more because they made more motors than they did tractors. Hope this helps, SAm in NS
