Farmall Height
Sean Hahn
11-21-2004 16:42:06
How much difference is the heigth between a M and a H? I used to have a H and I had to take the muffler off to get it in my shed.....my shed door is 80 inches high.....will a M fit in my shed if I pull the muffler off? I know I had a few inches from the top of the steering wheel to the door on my H....Please let me know, Thanks
IndianaDan
11-21-2004 18:41:55
 Re: Farmall Height in reply to Sean Hahn, 11-21-2004 16:42:06
Had to go out to the barn to check a battery I"m charging, so I took a measurement on my M. With new 13.6x38"s, it measures 79 1/2" to the top of steering wheel.
CNKS
11-21-2004 17:22:38
With standard tires, probably 11-38 for the H and 12-38 for the M, the height to the top of the steering wheel is 74 inches for the H and 78.25 inches for the M. So the problem is the muffler, and also your head if you don't get it below the steering wheel.
little john
11-21-2004 17:21:58
78 1/4 inches to top of steering wheel for the M.
74 inches for the H. According to Guy's Data Book.
Would vary a little according to tires, of course.
Nebraska Cowman
11-21-2004 17:15:57
just off the top of my head I'm thinking it will be real close depending on tire size. if you have a dirt floor you might dig down a little in the wheel tracks.
Nebraska Cowman
11-21-2004 17:15:39
Sean Hahn
11-22-2004 03:17:08
 Re: Farmall Height in reply to Nebraska Cowman, 11-21-2004 17:15:39
Thanks guys....I'll have to get another H then for it to fit....a M would be really tight if it would fit in....Thanks, Sean
