Farmall M manifold
rustyfarmall
11-22-2004 06:14:36
I have recently acquired a manifold with the part number 8035DD, casting code 5-24-Z. Can anyone tell me if this manifold would have better air flow than the original on my 1940 M? Is there any differance?
gusc
11-22-2004 19:19:28
 Re: Farmall M manifold in reply to rustyfarmall, 11-22-2004 06:14:36
Rusty,
You probably already know this but the M and Super M engines are not the same size.
CNKS
11-22-2004 09:32:55
I am not an expert, but I would guess that if it fits, and the SMTA has larger exhaust ports in the head, compared to the M (I don't know that), that for all practical purposes, it won't be any better. If the ports are the same size, then the "new improved" one should flow better, but I wouldn't bet on it, unless you have a distillate manifold, then I'm still not sure, so why did I answer??
rustyfarmall
11-22-2004 10:08:14
 Re: Farmall M manifold in reply to CNKS, 11-22-2004 09:32:55
CNKS, thank you for adding to the confusion, LOL, seriously, my M does have the high compression gas head, and the manifold in question does have a different appearance to it, but so far I have not measured the I.D. of the ports, and even if I did, I still don't know the I.D. of the ports on the head. I suppose I should ask the question on the pulling board, but it's more fun here.
CNKS
11-22-2004 11:26:31
 Re: Farmall M manifold in reply to rustyfarmall, 11-22-2004 10:08:14
ChadS will probably answer when he gets on -- I should keep quiet.
jonesy
11-22-2004 07:35:47
That is the "new and improved" design that they started putting on the Super M. Going buy the casting date that one went on a Super MTA in 54.
rustyfarmall
11-22-2004 07:42:12
 Re: Farmall M manifold in reply to jonesy, 11-22-2004 07:35:47
Yes, I came to the same conclusion, it is for a super MTA. I guess I haven't looked at a lot of manifolds but this is the first one I've seen that has a casting code on it.
