46 Farmall C
52 A Boy
11-22-2004 08:33:32
We are working on a Farmall C in FFA and we were wondering if it is a positive or negative ground system.
Any help would be appreciated.
52 A Boy
Novel Idea Guy
11-22-2004 11:34:51
 Re: 46 Farmall C in reply to 52 A Boy, 11-22-2004 08:33:32
Which terminal of the battery is connected to the frame of tractor? That will tell you what type of ground it is.
Peabody
11-22-2004 08:48:14
It was originally a 6 volt positive ground. Many have been converted in later years to 12 volt negative ground, accomplished by replacing the generator with a 12 volt alternator (with internal regulator), replacing the 6 volt battery with a 12 volt, installing a resistor in front of the coil on the hot wire from the battery, and replacing the 6 volt headlight bulbs with 12 volt bulbs. Oh yeah, and grounding the negative post of the battery to the tractor. Good luck on your project.
TRACTOR BOY
11-22-2004 08:41:23
'C' was not made until 1948. Should be Positive ground.
JIM
captaink
11-22-2004 08:46:29
 Re: 46 Farmall C in reply to TRACTOR BOY, 11-22-2004 08:41:23
If it is the original 6 Volt system, it is positive ground.
If it has been converted to 12-volt it would be negative ground.
