to bob m and the 10si with diode setup
bryan meade
11-22-2004 10:20:25
hey bob, thanks for the info in the other posts about using the 1n4001 diode. i was going nuts and didnt want to use the light. but one more question. im sure you have seen the 1 wire adapter plugs that you use to make a 3 wire to a 1 wire, i know that these will cause battery drain when off, i tried one. but if i make my own with the diode and resister can i just take terminal 1 (with diode and resiter) and go straight to (bat)terminal along with terminal 2 (already on bat terminal)? would this cause my altenator to stay (pulled in) and probably cause the regulator to burnout? or would that make it a 1 wire that didnt cause battery drain.
i would run the ign straigt through swith then to battery.
and thanks again for the diode trick.
bryan
gusc
11-22-2004 19:10:50
 Re: to bob m and the 10si with diode setup in reply to bryan meade, 11-22-2004 10:20:25
Run terminal #1 wire through the resistor or an idiot light to the side of the switch that is dead when the switch is off.
If you hook it to #2 and battery it won't be able to ever regulate the output of the alternator.
Bob M
11-22-2004 11:15:29
Bryan – If I understand your idea I don’t think it will work!! You still need to somehow shut off supply voltage to the #1 alternator terminal when you shut down.
Simply connecting the diode/resistor to the (hot) #2 terminal like you propose will result a small backflow of current into the regulator whenever the alternator is stopped. While it’s not likely to burn out the regulator, it will heat the resistor and will cause a dead battery if allowed to sit for more than a day or two!
Sorry!
bryan meade
11-22-2004 13:51:32
 Re: to bob m and the 10si with diode setup in reply to Bob M, 11-22-2004 11:15:29
ok, thanks for the quick reply, just thought i had a idea. but 2 wires wont be so bad.
thanks
bryan
