340 Int Utility Oil Seal Question
CharlesC(MO)
11-22-2004 13:13:17
Front crankshaft seal leaks - big time!
Can this seal be replaced without removing the front end of the tractor (tractor has FEL)?
What problems should I be looking for while I'm in there?
Thanks for the help.
parts man
11-23-2004 16:03:34
 Re: 340 Int Utility Oil Seal Question in reply to CharlesC(MO), 11-22-2004 13:13:17
That will depend on how tight the pulley is on the crank. Generally you will have to use a puller to get the front pulley off, in which case you'll have to remove the steering gear housing. Sorry!!
BTW, the seal goes in from the back side of the front cover so you have to take it off too.
