Super A Hybrid???
Dan K
11-22-2004 15:04:13
I just moved back to the country and bought a Farmall Super A (serial number 256199) from my recently-widowed neighbor. Since the carburetor's float pivot pin was severely pitted and the main gasket was in poor shape, I bought a carburetor kit and hit a snag. The kit for the above serial number didn't fit. Further investigation revealed an engine block serial number that looks like 354898 with a casting date that looks like *6-20-X*. The carburetor is a Zenith, not a Carter, etc.
What sort of a hybrid do I have here??? and what do I tell the carburetor kit merchant on my second attempt?
Thanks for your help. [I found the answer to a starter problem on this forum 2 days BEFORE I experienced the problem!!!!!]
Dan K.
CNKS
11-22-2004 17:46:36
 Re: Super A Hybrid??? in reply to Dan K, 11-22-2004 15:04:13
If you can't find the carb number as SAm suggests and you have a Case-IH dealer handy, take the old gasket or the fuel bowl with you and match it to his computer diagrams, as there were 2 or 3 Zeniths, most parts are probably the same, but the gaskets are different.
SAm in NS
11-22-2004 17:37:35
Your tractor serial number looks to be a 1948 (I haven't checked, just click "Serial Numbers" to your left under "Research & Info". Your block serial number would appear to be in 1954. Now the casting code you posted appears to be for the 20th of June 1952. I would suggest you try and clean your block serial number a bit better because I can't see how you can have a '54 serial number and a '52 block (not that it would be impossible:). You should probably check the rest of the tractor as all of the major cast components should have the codes on them and that'll give you a better idea when it was built. As to your carb. problem I think all of the Zenith carbs have a small circular disc on the top surface which will yield a model number if you can clean it well enough. Hope this helps, SAm in NS
Dan K
11-23-2004 14:06:22
 Re: Super A Hybrid??? in reply to SAm in NS, 11-22-2004 17:37:35
Folks, thanks for the help.
Regarding the carburetor: I already had the small circular disc on the top surface as clean as a pin... just didn't know what I was seeing. It shows model no. 12613A with the accompanying no. of 375560R91 (see post from "Kevin in Va." on 08-16-2004 04:04:53).
The "Tractor Carburetors - OEM Cross Reference Guide" lists this carburetor as
OEM # -- Carb# - Manu. - Applic. --- Engine
12613A - 161X7 -- IH -- C113,C123 - A;B;C;SUPER C
[note: it doesn't mention Super A!! and it doesn't show a rebuild kit].
Fortunately I DO have a Case-IH dealer about 8 miles away and I've seen his computer searching for a sediment bowl. I'm much closer to a solution on this problem.
Regarding serial/casting numbers: The 354898 # (including the R1 suffix) IS behind the oil filter... and finally (with the aid of a 1 mil candlepower light) I found the stamped-in serial number plate: ----- ----- --- | FCM G| | 155540 | ----- ----- ---
That's right -- ONE-5-5... [It is smaller than I imagined after seeing the casting numbers and is behind the coil and exactly hidden by the throttle rod.]
The casting number 351687R1 is cast upside down on the very back of the clutch housing. The date *9-22-47* (all *'s look like slotted screw heads) is cast in the transmission below the shift lever.
The block date of *6-20-X* is still a puzzle. The right screw head image appears to be jammed up against the intersection of the X.
Any further help with these numbers?
Thx, Dan
SAm in NS
11-23-2004 15:16:08
 Re: Super A Hybrid??? in reply to Dan K, 11-23-2004 14:06:22
It looks to me as though you have a 1948 Super A with a 1952 Super C motor. The prefix for the C/Super C was (I think) FCM, and the serial number corresponds to a late 1952 Super C. This also matches up with your block casting date. So you probably have the C-123 engine as opposed to the C-113 engine that was in most Super A's. It is also probably turning a bit faster. Just out of curiosity, do you have a water pump? Hope this helps, SAm in NS
Dan K
11-23-2004 18:41:17
 Re: Super A Hybrid??? in reply to SAm in NS, 11-23-2004 15:16:08
Uh... well, I don't SEE a water pump. There is a radiator hose neck bolted to the top, front, center of the block. At the bottom of that neck is a bracket which holds the fan shaft with a 2-slot pulley. The larger belt is driven by the drive pulley on the crankshaft. The smaller belt drives an alternator. I don't see any other possibilities for a water pump... just the direct-drive hydraulic pump.
Dan K
Stan(VA).
11-22-2004 19:46:04
354898 is probably the block's casting number, not serial number. That would be correct for a 1952 Super A or Super C (still a replacement block for this tractor). The casting number is behind the oil filter, the serial number is on a machined flat above the distributor (with prefix FAAM or FCM depending on what it came from).
Stan(VA).
