Power steering hand pump leaking again on 574
shocker
11-23-2004 03:58:40
I replaced the leaking original pump (with a used one)about 2 yrs. ago and now it is leaking, i have been told it is hard to rebuild and since there is some movement in the shaft i think i will get a new one for $650.00 what do you think?
the tractor vet
11-23-2004 05:57:45
 Re: Power steering hand pump leaking again on 574 in reply to shocker, 11-23-2004 03:58:40
All ya need to do if it is leaking under the steering wheel is replace the seal and it is not a tough job , you will need a steering wheel puller and two 1/4 inch fine threaded bolts about 4 1/2 inches or longer, snap ring pliers and a 1/4 28 bottoming tap and about a half hour . Just pull the wheel and remove the snap ring put the wheel back on and give a quick twist either way and out pops the seal install new seal repace snap ring and install wheel all done.
