Flow-Rater
Allan in NE
11-23-2004 12:24:38
Hmmm,
Flow rater only showing 1500 psi rear pump hydraulic pressure on my newly acquired 966 at idle.
That kinda smells a little. :>(
Allan
Aces
11-23-2004 20:40:33
 Re: Flow-Rater in reply to Allan in NE, 11-23-2004 12:24:38
If you have the flow rator in the port on the plate the pump is bolted to you will check the whole system, if you have it out a remote you will check thr whole system. No way I ever knew of to check pump alone or the relief alone.
Heat Houser
11-23-2004 20:08:54
Where have you installed the flow rater? If between the pump and the rest of the system, I would suspect a bad pump. If pluged into the remote outlets, then the tractor's relief is still in the "system" and may be dumping your flow. A typical drop in pressure when going from hi idle to idle is around 150 psi or less (assuming a good system). If more, stuck relief, cracked valve casting or something similar.
Allan in NE
11-24-2004 01:34:21
 Re: Flow-Rater in reply to Heat Houser, 11-23-2004 20:08:54
HH,
With the flow rater plugged right into the left set of remotes.
Replaced the flow control valve and it didn't help, that's why I think it might be a wobbled out pump body, especially in light of the fact that this oil is very black and the system has obviously been neglected.
The thing has been setting for 5 years too, but it darned sure ought to pressure up to more than 1500 lbs I'd think.
Allan
George G
11-23-2004 15:53:01
Book I have,show's 2000psi and 12gpm for the 966.
Aces
11-23-2004 14:31:07
Allen you may get it before you get it hot but I think you would need new pump to do that, but rated load rpm is the proper test rpm on all IH.
Aces
11-23-2004 12:39:30
Allen that may not be all the bad they should be flow rated at rated load RPM. Having said that it should do better if flow is ok at idle.
Allan in NE
11-23-2004 13:27:34
 Re: Flow-Rater in reply to Aces, 11-23-2004 12:39:30
Well,
The darned oil is really dirty (black in fact), probably has a plugged filter and was checked cold too.
But she sould pump a good 2250 psi hot and at idle, I'm thinkin'.
So, the darned pump is coming out to get a look-see. Better to do it now and not have any surprises later.
Allan
