setting points on an M
mo money
11-23-2004 19:29:18
what is te procedure for setting the dwell on the points? thanks in advance
Hayfarmer
11-23-2004 20:13:05
 Re: setting points on an M in reply to mo money, 11-23-2004 19:29:18
I use a remote starter button, remove cap and watch the shaft, hitting the button until the points are open the most, ie on the top point of the lobes. Stop it there and set points. Have also used wrench on end of crankshaft, front end, to turn it to bring distributor shaft around to where points rest on high point.
CNKS
11-23-2004 20:11:39
You don't need to set the dwell, just set mag points at 0.013, distributer at 0.020, with the rubbing block on one of the high sides of the cam.
