w6 radiator removel Need Help?
sjh
11-24-2004 13:24:47
The bolts that hold the rad down are rusted so bad that i can not get them off. Can I torch them off, or is this a big no no?
Thanks
Scott
El Toro
11-25-2004 06:12:19
 Re: w6 radiator removel Need Help? in reply to sjh, 11-24-2004 13:24:47
Hi Scott, I would use a cutting torch to heat them red hot if you can stay away from damaging
the radiator. The cutting torch is better so you can put the heat where it is needed, but do not squeeze the trigger. Hal
Geoff NY
11-24-2004 13:34:54
I would stay away from that radiator with a torch myself. They are studs, so usually one end or the other will come with some persistance and some penetrant.
