Farmall H vs Super H
JJ.Johnson
11-24-2004 14:41:10
Dumb question? is there a sure way to tell a Farmall H and a Super H? The Auctions I attend, the H's decals all seem to read Super H.Please help.
rustyfarmall
11-24-2004 21:40:29
 Re: Farmall H vs Super H in reply to JJ.Johnson, 11-24-2004 14:41:10
Look on the right side of the engine block, somewhere in the area of the oil filter. The super H will have C-164 cast into the block. The non-super H will have just a part number.
Rich - Wi
11-24-2004 15:14:53
The Super should always have disc brakes and if you look on the serial no. tag it should start with SH_____ _.
Bob M
11-24-2004 19:45:42
 Re: Farmall H vs Super H in reply to Rich - Wi, 11-24-2004 15:14:53
Also check the last character of the pour date code on major castings (block, transmission, axle housings, etc). A Super H should have most date codes ending in Y or Z (for 1953 and 1954). Late codes X (1952) are suspect, and anything earlier in the alphabet means a regular H.
Guy Fay
11-24-2004 17:40:14
Actually, some Farmall Hs had disc brakes. Go by serial number.
