Repower an H
r4etired
11-24-2004 17:54:36
Ihave an H in need of an engine,I have done V8 repowers and are happy with them . one a 345 in a 560 the other a 345 in my M.I thought finding a Chev 2.8 liter V6 carburated .engine with a standard transmission would be no problem. They made thousands of S10 pickups, I'm having no luck in finding one.Anybody know where I can find one.prefer within 250 miles of DesMoines,Ia.Really appreciate any help on this Thanks.
russ johnson
01-22-2005 12:10:19
 Re: Repower an H in reply to r4etired, 11-24-2004 17:54:36
i just found your forum while serching the archives and was hoping you could help. i have a md farmall that i want to put a 400 sb chevy in any help onmaking the clutch-flywheel work would be greatly appriciated
SGT K
11-25-2004 12:33:42
If you "get err done" I would sure like to see a picture of it.
Paul
rustyfarmall
11-24-2004 21:32:51
You might have better luck looking for a 4.3. Those 2.8s were kind of an odd-ball engine, didn't seem to share any parts with any other GM engines.
r4etired
11-25-2004 05:39:53
 Re: Repower an H in reply to rustyfarmall, 11-24-2004 21:32:51
The problem with a 4.3 is they are all throttle body injected, and require a computer to function. I have enough trouble figuring out the computer I;m on. Don't think I could make an engine run with one. I did find out they used a few 4.3 carburated engines in marine applications.
nerstrand44h
11-25-2004 08:43:19
 Re: Repower an H in reply to r4etired, 11-25-2004 05:39:53
Not all 4.3 V-6's are injected. Look for one out of a 86 or older 1/2 ton GM pickup. It will be a carbureted engine with a 4bbl intake.
rustyfarmall
11-25-2004 06:06:38
I am certainly not an expert on such matters but I would think you could just toss all of the electronic stuff including the throttle body into the trash can and start all over with a carburetor. Remember, the 4.3 is nothing more than a 5.7 with the front two cylinders cut off. It also seems to me that there is a class of nascar racing that uses those 4.3 engines. I could be wrong but I doubt if they have left the electronics intact for that application.
lee
11-25-2004 19:04:38
 Re: Repower an H in reply to rustyfarmall, 11-25-2004 06:06:38
right, just find an intake and carby and scrap out all the efi stuff
Fitter
11-25-2004 05:38:36
I agree a 4.3 better choice. Have had two Astro Vans with 4.3 almost 2xx,xxx on each and no problems. I'm not sure that the 2.8 will run that long. Just my thoughts.
