Removing an oil seal by the belly pump
dave westlund
11-25-2004 18:59:51
I have an oil leak on my h where the belly pump sits. It actully leaks out of the oil seal on the transmission case. I am having trouble removing the 4 tappered bolts so I can remove the casting. I have two of them out but spent the last hour trying to get the other two out with no success. Is there trick to removing them?
Dave
RayA
11-25-2004 20:07:47
 Re: Removing an oil seal by the belly pump in reply to dave westlund, 11-25-2004 18:59:51
Hey Dave, I think you are talking about the tapered bolts that hold the coupling yokes together that drive the tranny? If so they are a beast. If I remember right I used the biggest wrench I could fit in there, a cheater bar and a sledge to get mine busted free. I think I also tried to put a bar behind them and tried to pry them out a little. A good amount of cussing every so often seemed to help also, haha. When you replace that seal you might look at the yoke that passes through it into the tranny. I replaced mine and I probably should have installed an Easy Sleeve that some of the guys have talked about on this forum as mine is leaking again. Hope this helps you out some.
dave westlund
11-26-2004 17:42:00
 Re: Removing an oil seal by the belly pump in reply to RayA, 11-25-2004 20:07:47
Hey Ray,
I took your advice and it worked. I little cuss'in!!
thanks
