135 piston and sleeve kit
Hobo,NC
11-26-2004 04:45:09
I orderd a 135 piston and sleeve kit for my 100 by mistake. it has the gaskets and rod bush'ns also. If enny one is in need of a good kit at a deal mail me. i will let it go at dealer cost
@ 375.00 + freight . I will take a credit card or paypal.
Brown Dirt Cowboy
11-26-2004 13:50:16
 Re: 135 piston and sleeve kit in reply to Hobo,NC, 11-26-2004 04:45:09
Hobo, I have the 135 sleeve and piston kit in my B had to have block bored for the 31/4" kit. Been running it for about 6or7 yrs now and have had no problems with it. Have an A that is going to get the same thing when it needs overhauled. Tom
lee
11-26-2004 09:33:19
Why not return it for the correct one.
Hobo,NC
11-26-2004 15:17:25
 Re: 135 piston and sleeve kit in reply to lee, 11-26-2004 09:33:19
I reorderd the correct kit. Talked to their tech man and was sure the number he gave me was the 135 kit. i am not gonna hold'em to it cuzz I also had the number wrote down fer the 123 3 1/4" kit also. If you ever try and order a kit out of a TISCO catalog you would know what I mean. I got free freight on the kit but will havta pay freight both ways if I return it. Its a good buy at 375.00 and would save me the freight charge.
Brown Dirt Cowboy
11-26-2004 19:56:33
 Re: 135 piston and sleeve kit in reply to Hobo,NC, 11-26-2004 15:17:25
Hobo. The 123CI engine is a 31/8" bore. Tom
Hobo,NC
11-27-2004 12:51:49
 Re: 135 piston and sleeve kit in reply to Brown Dirt Cowboy, 11-26-2004 19:56:33
I here the 100 came with the 3 1/4 bore and I here their was a over bore kit for the 100 3 1/4"
either way mine had the 3 1/4" overbore kit with the steped head piston. Parts book reads C123 CID GAS 4 CYLINDER ENGINE
SUPER A-1 & AV-1 S/N 310300 & UP,
SUPER C; 100 & 200
(stepedhead piston) (cyl. sleeve 3-7/16 O.D. at seal)
Basic kit is 3 1/4 bore.
I was thinking the 3 1/4 bore was a 135 and some one had changed it so i had he 135 in mine when I order it. Tech said the 3 1/4 was STD for my 100 but the 135 sleeves were .030 larger at the sleeve seal. this is the first 123 engine I have been into. I do have a 140 with 123 and know the sleeves or 3 1/8. I don't know for sure what the 100 had in it new. I do know it had been into before. Who knows after 50 years what some farmer dreamed up.
Brown Dirt Cowboy
11-27-2004 14:44:51
 Re: 135 piston and sleeve kit in reply to Hobo,NC, 11-27-2004 12:51:49
Hobo. I checked 4 reference books that I have and all of them say that the 100 should have the 123CI engine which is the 31/8X4" block. Most likley your tractor has already been oversized. Tom
Hobo,NC
11-27-2004 15:24:46
 Re: 135 piston and sleeve kit in reply to Brown Dirt Cowboy, 11-27-2004 14:44:51
Oversized, farmerized, simonized, bab'tized, pulverized, circunzised, old boy had a hard life befor I got it. The guy I got it frome said it had a super kit in it. thats all I know. it ran fine with some smoke til the gear on the hydraulic pump got loose and took out the governor, cam gear and the hydraulick pump. after i got the engine apart the rings were shot. Not know'n much about this engine I drove in head first gonna do a complete rebuild.
ran in to my fist problem last night, install the rear seal (dust seal) and covers. i soaped down the aera around the seal house'n and blew air from the inside and i had leakage. removed it and put some good silicon sealer on the gasket and reinstalled. Have not rechecked it but sure it will not leak around the gasket. Thanks for your reply.
Brown Dirt Cowboy
11-28-2004 05:45:32
 Re: 135 piston and sleeve kit in reply to Hobo,NC, 11-27-2004 15:24:46
Hobo. I am going into my '39M this winter, won't know until I get in there if it has been oversized or not, but it will be when I get done. Good luck on your rebuild. Tom
Hobo,NC
11-26-2004 04:46:42
fergot to unhide email
