starting 47M on LPG
Barrymiller
11-28-2004 15:29:23
I have rebuilt the engine on this tractor installed new plugs, points,coil and wires. and Now I would like to start it. The tractor has a LPG system and I have fuel. The distributor has been timed to TDC but I can"t get the engine to fire or even try to start has anybody got any suggestions. I have blue spark to the plugs and coil.
John A.
11-28-2004 17:59:47
 Re: starting 47M on LPG in reply to Barrymiller, 11-28-2004 15:29:23
Barrymiller, Try this.....
1st. Shut the valves in the tank off. Make sure they are not leaking through.
2nd. Let set for a while, it may be flooded.
3rd. Squirt a little gasoline in #1 and #4 cylinders.
4th. leave valves OFF, start cranking tractor, with one hand on starter handle, have the other on the vapor valve. When she hits open the valve. She should run, if all is correct. If it does run the problem is the diaphrams in the carb. Go to your LP dealer he should be able to get them for you. If not hollar back and some of us have the names of places to get replacement diaphrams. Good luck! Hollar back on haw it goes.
Later,
John A.
Barrymiller
11-30-2004 07:39:41
 Re: starting 47M on LPG in reply to John A., 11-28-2004 17:59:47
Thanks I tried your suggestion. Looks like I have aproblem with the regulator. Could you send info about new diaphrams.
Barrymiller
11-30-2004 14:37:54
 Re: starting 47M on LPG in reply to Barrymiller, 11-30-2004 07:39:41
John A I have uncovered my email. so you can send me the info about the diaphrams.
Thanks
John A.
11-30-2004 11:56:32
Barrymiller, You need to send me an email so I can send you name of a supplier for new diaphrams.
Later,
John A.
