H4 Magneto Y Designation
MagMan
11-28-2004 16:03:55
I just spent the last hour looking through the arcives. Does any one know what motors the H4 magneto with the Y at the end of the serial # and off set mount fits besides the Continental IY-69 motors on the balers and combines??? JON
gene b
11-28-2004 18:48:00
 Re: H4 Magneto Y Designation in reply to MagMan, 11-28-2004 16:03:55
The only motors that i know of are the CONT that were used on the combines. Why cant you change the mag drive spacing on the teeth to make it work on an I-H block. I am going to put one on a block and see if it would work as long as the marks on the crank and cam were lined up correct. I dont see any reason that it should not work as all we are doing is place the mag drive so it fires on T.D.C.
MagMan
11-29-2004 03:04:30
 Re: H4 Magneto Y Designation in reply to gene b, 11-28-2004 18:48:00
Let me know Gene. JON
El Toro
11-28-2004 16:33:56
Hi Jon, Is the Y69 engine the same as the IH-69?
If it is, it fits a lot of Continental engines, Hal
magman
11-28-2004 16:44:06
 Re: H4 Magneto Y Designation in reply to El Toro, 11-28-2004 16:33:56
I am not sure I know of the 50 T balers had that engine I guess. JON
El Toro
11-28-2004 18:00:56
 Re: H4 Magneto Y Designation in reply to magman , 11-28-2004 16:44:06
Hi Jon, This is the Fairbanks-Morse Mag number for the Y69 engine. FM-X4B16,A, B and the Wico
is XH1648. Don't know if this helps, Hal
