Farmall H throttle lever bushing
John in Ct
11-28-2004 19:10:22
Is the bushing for a Farmall H throttle lever still available? My parts book doesn't list it. If not, does anyone know where I can get a NOS bushing or complete throttle lever? Thanks!!
John in Ct
11-29-2004 09:55:32
 Re: Farmall H throttle lever bushing in reply to John in Ct, 11-28-2004 19:10:22
The part I am looking for ,what I call a bushing in the throttle handle. The parts book doesn't list is seperatly but calls it a hub, so I am in need of a hub. Or I would be happy with a NOS "51348 DAX Gov. control handle with hub" I got an aftermarket one (not sure of the brand) it would work ok for a while but it isn't made like the origional. Thanks.
riverbend
11-30-2004 16:24:30
 Re: Farmall H throttle lever bushing in reply to John in Ct, 11-29-2004 09:55:32
If you can not find a new lever, you might try drilling out the old 'bushing' and pressing in a new sleeve to improve the fit on the pin.
If the lever is slipping and ruining the tooth, straightening the lever will solve the problem. It appears that the heel on the short side and the tooth should be the only parts of the lever that touch the cap.
Whoops
11-29-2004 11:49:47
 Re: Farmall H throttle lever bushing in reply to CNKS, 11-29-2004 11:47:11
That should be www.weberstractorWORKS.com.
CNKS
11-29-2004 07:28:52
OEM Tractor Parts -- 800-283-2122 -- sells the complete assembly or the throttle lever only.
riverbend
11-29-2004 06:18:37
If you mean the throttle shaft in the carb, the bushing is pn 45109DA. I don't know if they are still available, but I was able to buy one from the local IH dealer a couple years ago.
The throttle lever by the steering wheel does not have a separate bushing.
MagMan
11-29-2004 03:46:12
I am not sure about a bushing. I know you can get the M&W style Throttle under $20.00 usally. JON
John in Ct
11-29-2004 06:07:25
 Re: Farmall H throttle lever bushing in reply to MagMan, 11-29-2004 03:46:12
I want to keep the origional throttle lever. I got a new aftermarket one and it isn't built as good, so I want to fix my origional throttle lever.
