does the dist drive gear need to be timed to the c
Chad from MI
11-29-2004 06:59:19
On my H well both of them I think I have this screwed up.
Does the dist drive gear need to be timed to the cam gear? I think on both of my tractors after putting the engines back together I did not have the dist housings bolted on the tractor. Maybe this is the source of my timing problems. I have been pulling the whole dist drive assemby clean out of the block to adjust the rotor cap to the dist cap. I didn't realize you could just pull the very top of the assembly out. Any how if the dist drive gear that goes in the block is suppose to be timed to the cam shaft gear how do you time it after the front cover has been installed or is this not a big deal?
Chad
Novel Idea Guy
11-29-2004 07:11:09
 Re: does the dist drive gear need to be timed to t in reply to Chad from MI, 11-29-2004 06:59:19
Yes, of course they need to be timed. How do you do it after the front cover is back on? Very carefully. In fact, I don't think you can install the distributor drive without the front cover installed. The distributor drive bolts into the front cover from behind, does it not?
Find TDC on the compression stroke, set the distributor so the rotor points at the #1 cylinder's socket on the distributor cap, install the distributor, then double-check your work. You can rotate the distributor to fine-tune the timing.
Chad from MI
11-29-2004 07:26:56
 Re: does the dist drive gear need to be timed to t in reply to Novel Idea Guy, 11-29-2004 07:11:09
Thanks that is what I did.
