Batteries for 560 wheatland
Jim Ward
11-29-2004 16:29:45
Does anyone know what batteries a 560 wheatland is suposed to use? It is a diesel 12 volts but I do not know if its supposed to have 2 12 volts in parraell (misspeled I think) or 2 6 volts in series ? Because there is a lot of room up there... Any help would be apperciated.... Jim
ken sampson
11-29-2004 20:09:23
 Re: Batteries for 560 wheatland in reply to Jim Ward, 11-29-2004 16:29:45
560 diesel has 2 group #3.
jim ward
11-29-2004 19:00:18
Thanks guys ..... ..... .....Your great ..
ejr
11-29-2004 18:50:52
I have two 560 ds just use one heavy duty 12volt battery less posts to keep clean and I use them in the winter no problem.
farmall300u
11-29-2004 18:05:39
If it was mine, I would get two 12 V marine batteries and put them in parallel vs two 6-volt in Series. More Volt/Amperes on a diesel is a good thing.
Hugh MacKay
11-30-2004 02:05:42
 Re: Batteries for 560 wheatland in reply to farmall300u, 11-29-2004 18:05:39
You can obtain just as many cranking amps from 2-6 volt batteries in series as you can from 2-12 volt hooked paralell. That is providing you buy the right batteries.
Nebraska Cowman
11-29-2004 16:46:35
yes, The diesel uses two 6 volts
Ken S.
11-29-2004 20:11:40
 Re: Batteries for 560 wheatland in reply to Nebraska Cowman, 11-29-2004 16:46:35
2 of the group 3 should fit.
Jim Ward
11-29-2004 16:57:20
Do you know what group they are?
Nebraska Cowman
11-29-2004 17:00:37
 Re: Batteries for 560 wheatland in reply to Jim Ward, 11-29-2004 16:57:20
parts book calls for Auto-lite 2H-135R whatever that means.
JIm Ward
11-29-2004 17:03:21
 Re: Batteries for 560 wheatland in reply to Nebraska Cowman, 11-29-2004 17:00:37
That should mean a group 2 thanks.. Jim
Hugh MacKay
11-29-2004 17:18:20
 Re: Batteries for 560 wheatland in reply to JIm Ward, 11-29-2004 17:03:21
Jim: I had a 560D, mine was a Farmall, but think that compartment is close in size. My experience go for the largest batteries that will fit in there. You wont regret it.
steveormary
11-29-2004 17:48:39
 Re: Batteries for 560 wheatland in reply to Hugh MacKay, 11-29-2004 17:18:20
Jim Ward
My 706 diesel had 2 6volt batteries in series. I got my battery replacements from the CIH dealer.
steveormary
