plow hitch
Max adams
11-29-2004 17:55:35
Max I think in my pile of collectables I have another 2pt plow hitch. I wonder if the 312 and 412 use the same. I will check tommorow and get some measurments, When I go to auctions I buy any thing that has the points, Then I either make drawbars or 2pt to 3pt adapters.
max adams
11-30-2004 14:04:20
 Re: plow hitch in reply to Max adams, 11-29-2004 17:55:35
as far as i can tell the 312 and 412 are the same.where are you located? Hugh is right i could make my own, but if i can find an original hitch that would make it nice. i will open my e-mail so you can get in touch with me. i do appreciate it.
Hugh MacKay
11-30-2004 03:15:39
Max: The part number for what IH call the pull beam coupling on the 312 and 412 plow is 526 832 R91. That part is basically two fast hitch forks joined by a round shaft gives proper spacing betwwen forks and would judge is about 1.5 to 2 inches in diameter.
I think you could quite easily fabricate that from fast hitch forks. The forks do have a turned up end towards shaft. I didn't look at photos retired posted in gallery, but the photo he sent me was quite clear. I think with a copy on that photo you could come up with just what you need in fabrication.
I went through my plow parts book and don't see any other plow models with that exact part.
