1066 Hydro
JLE
12-01-2004 10:11:14
1066 Hydro, has no reverse, pulls as normall in forward. Using on ditch bank mower, run one day put in shed, went to back out next day, no back up!!
Any ideas????
Bernard le mécano
12-02-2004 08:44:55
 Re: 1066 Hydro in reply to JLE, 12-01-2004 10:11:14
Hi JLE, check if the hydro lever adjustemt is ok, may be the lever is worn and the reverser valve don't close enough, may be reverse relief valve is bad or the spring on the center section (neutral-valve) is broken or the snap-ring is pop out. You can plug the 2 small pipes on the left of the transmission housing. Be carefull when you make a test, the foot-inch pedal don't work, you stop the tractor with the lever only. Good luck!! Bernard le mécano Québec Canada
Aces
12-01-2004 16:59:04
JLE If I remember right they have a relief valve for forward and one for reverse they are pilot operated valves which means they build pressure as needed until they get to the set point something like 6000 PSI so I could see one working and one not If it got some dirt in it maybe can start to build pressure, but has to be in reverse circuit.
the tractor vet
12-01-2004 11:48:11
Now i am not the gruru on the Hydro's but i would think that it is a stuck valve or something in the linkage. And at this moment i can't even look in my books as a buddy has them , HUMMMMmmmm i guess i'll have to go and get them back.
