Rear main seal on '41M
Ray M41
12-01-2004 14:41:19
The rear main seal on my M started leaking. My book says I must split the tractor to replace it. I remember my FIL pushing the rear seal up, over, and around the crank in my Pontiac when we overhauled it. Can this also be done on the M, or must I have to split it?
Bubba
12-03-2004 11:26:38
 Re: Rear main seal on '41M in reply to Ray M41, 12-01-2004 14:41:19
I split mine.
Aces
12-01-2004 16:44:13
Ray you will have to remove the pan split the tractor remove the clutch flywheel remove the to halves of the seal remove the old felt seal from the aluminum holders and install the felt seal you will need new gaskets for the felt seal holders. Put some oil on the felt after you install the felt and reassemble.
Ray M41
12-02-2004 06:03:53
 Re: Rear main seal on '41M in reply to Aces, 12-01-2004 16:44:13
Appreciate the response. I was afraid of that. I was still hoping someone had somehow aced it.
