Does my H need a head gasket?
John in Ct
12-01-2004 19:35:02
I noticed when warm, there is some oil near where the block and head meet. It seens to kind of disapear when everything cools down. I washed my engine with safty kleen so we could do the water jacket, valve cover, etc. and I use to spray WD 40 on my engine when the H was put away for the winter. Could it be WD 40 or Saftey Kleen that got absorbed into the head gasket leaking out when the engine is warm? The oil seems to be very thin like WD 40 but I never heard of oil being absorbed from the outside then leaking back out. I hope that is what it is. Thanks.
MarkO
12-02-2004 10:39:35
 Re: Does my H need a head gasket? in reply to John in Ct, 12-01-2004 19:35:02
I had the same issue, mine turned out to be a leaky valve cover.
captaink
12-01-2004 20:11:36
Probably not especially if the oil is on the manifold side. If the oil comes when warm and goes away when it cools off, I wouldn"t bother with putting in a head gasket unless it is a show tractor or it actually started seeping continuously when it was warm or the engine was not running right.
