460 giving me fits
kyhayman
12-02-2004 13:12:57
Got an IH 460, came in broke in two at the clutch but running. Got it back into a 'tractor', replaced the clutch, everything appeared ok. Been trying for 2 days to get it running and I can not get fuel out of the pump. Got fuel to the pump without air in it no problem. Pump is working, some bubbles from the over flow tube but no fuel. Tractor wont start and am not getting fuel to the injectors. I know the pump is supposed to self belld but any ideas. I realize it could be a bad pump but it is hard to believe that the pump suddenly quit.
captaink
12-02-2004 13:41:13
 Re: 460 giving me fits in reply to kyhayman, 12-02-2004 13:12:57
Is the shutoff cable keeping the pump shut off by chance? It may have gotten damaged when the tractor broke. You might also want to check the fuel supply and return lines to make sure they were not damaged. (Just looking for the simple, cheap stuff that you probably already looked at.) =:-)
Otherwise loosen all the injector lines and crank it over until you start to see smoke come out the exhaust. Then tighten them up, glow plug the old girl and it should fire up.
Good luck!
