IH F-14 Sleeve
Larry Jensen
12-02-2004 16:39:46
I need a sleeve for a F-14. It has 3 1/8" aluminum pistons.
Sloroll
12-03-2004 16:05:23
 Re: IH F-14 Sleeve in reply to Larry Jensen, 12-02-2004 16:39:46
Seeing that it is an aluminum piston your tractor has probably been resleeved at least once. Could be that a C or Super C sleve will fit that piston. I know it is the same resleve kit for an F-14 as those models because I used them in my F-14.
Larry Jensen
12-04-2004 22:47:44
 Re: IH F-14 Sleeve in reply to Sloroll, 12-03-2004 16:05:23
I knew it had been resleeved because of the bore size and aluminum pistons. Maybe someone has a sleeve 3 1/8" bore for a C. Thank a lot for the info!!
