656 Hydro stops pulling
Bill46
12-03-2004 10:07:17
I have a 656 Hydro my dad had bebuilt just before his death. He spent a great deal of money on getting it fixed because it would not pull when hot.
Now, after just 30 minutes of light work such as mowing the thing starts to slow down and not pull.
I know I have done all I can, and he had just gotten it rebuilt 200 hours ago...any ideas?
I have never been around a Hydro that much, but do not want to get rid of it becaause it was dad's.
IH GARY
12-09-2004 18:20:14
 Re: 656 Hydro stops pulling in reply to Bill46, 12-03-2004 10:07:17
Need to isolate the hydro from the drive control valve and foot-inch valve. Remove the two steel lines from the left side of the hydro housing and cap the fittings coming from the housing. Don't worrym about plugging the lines only a small amount of oil will come out.Use the tractor like you do and see what happens. Be careful because with the fittings capped the foot-inch valve won't stop the tractor. Will have to use the S-R lever to stop the tractor. If hydro pulls good problem in drive control valve or foot-inch valve. If pulls the same trouble in hydro then need to run flow-rator check on center section. If want tractor fixed email me. Will give more info.
Bill46
12-10-2004 05:16:39
 Re: 656 Hydro stops pulling in reply to IH GARY, 12-09-2004 18:20:14
Thanks Gary...I will nto get to it until after the holidays...but I will let you know what happens.
Have a fine holiday.
IH Gary
12-09-2004 18:26:31
Forgot to ask does the tractor pull in reverse or is it only weak in forward also where is the S-R handle at when the tractor won't pull
IH Gary
12-05-2004 06:23:59
Will try to help you. First thing don't put in thicker oil. Might check foot-inch vavle adjustment. Pedal shouldn't come against platform. Would like to know what was done on the hydro overhaul. If the valve plates.bearing plates,pump block and motor block weren't refaced that could be your problem. There is a easy way to test this unit. Get back with me and I will explain how
Bill46
12-06-2004 05:03:06
 Re: 656 Hydro stops pulling in reply to IH Gary, 12-05-2004 06:23:59
I will check the adjustment Gary, I have no idea of what he had done. He pulled the entire unit out and took it to a man in Tennesse for rebuild. I know he spent a stack of money on it,
Joe C.
12-04-2004 17:30:31
The Hydro pump filter mihgt be stopped up. Or mabey needs new hydro oil. For not to be pulling the oil is getting thin. so try i thicker oil. It might help. Get back with me if you need anymore help.
Nebraska Cowman
12-03-2004 10:10:17
are you trying to run it in high range?
Bill46
12-03-2004 10:14:20
 Re: 656 Hydro stops pulling in reply to Nebraska Cowman, 12-03-2004 10:10:17
no...I do not think so Cowman. Guess I had better look tonight. I am new to this thing. It moves awful slow to be in a high range. Like I said...it does fine until it gets warmed up.
Nebraska Cowman
12-03-2004 10:16:32
 Re: 656 Hydro stops pulling in reply to Bill46, 12-03-2004 10:14:20
another thing that happens is the lever gets a grove worn it it where it rubs on the quadrent. try holding the lever over.
Bill46
12-03-2004 10:26:01
 Re: 656 Hydro stops pulling in reply to Nebraska Cowman, 12-03-2004 10:16:32
Thanks Cowman...I will look it over. I want to keep it like I said.
I am like some of you guys all at once. I am tractor poor by adding dad's tractors to the collection.
I wanted to try and get this one right because he really liked it.
