F-30manifold heat shield and M mag cutoff setup
phdl
12-03-2004 14:20:27
I've checked a number of places but can't find:
F-30 dual fuel manifold heat shield. It's different than the ones onthe F-20. I'd settle for a pattern so I can make one up.
M magneto cutoff for my early '40(#11565).I need the original style switch on the mag, the cable, and the brackets for the cable.
Anyone have any ideas? Thanks
MagMan
12-04-2004 10:04:27
 Re: F-30manifold heat shield and M mag cutoff set in reply to phdl, 12-03-2004 14:20:27
hi phdl, What do you have for a mag. I have one here that is origanel maybe even off a 40. That I can rebuild.Let me know if you have any interest. JON
MagMan
12-03-2004 14:56:10
I may have something let me check. JON
MagMan
12-03-2004 15:58:41
 Re: F-30manifold heat shield and M mag cutoff set in reply to MagMan, 12-03-2004 14:56:10
third party image
Is this what your looking for this is missing a few little cable mounting parts I guess. If the link does not work try parts and pieces to tha left and mag switch. JON
phdl
12-03-2004 18:20:02
 Re: F-30manifold heat shield and M mag cutoff set in reply to MagMan, 12-03-2004 15:58:41
Thanks Jon,thats it. Ido need the brackets that hold the cable , and the cable. Did you do the mag in the photo? It looks terrific!
Peter
MagMan
12-03-2004 18:29:45
 Re: F-30manifold heat shield and M mag cutoff set in reply to phdl, 12-03-2004 18:20:02
Yes thats one of my babys. Thats a Y designation for a baler or combine. I have not found everything it fits yet to list it for sale. I will keep an eye out for the complete switch for you. JON
justin w
12-03-2004 18:42:34
 Re: F-30manifold heat shield and M mag cutoff set in reply to MagMan, 12-03-2004 18:29:45
third party image
I should have another NOS Switch available, or possibly a used one with the cable support. I also am reproducing the cables.. the pic is of the button on the cable. Email me for more info.
