Farmall 504 wide front.
Kelly Mehling
12-03-2004 14:52:55
I have a 504 with single front. Would like to put a wide front under it. I think the factory front had the tie rods in the front, and I want to stay away from that. Can someone tell me which schwarz front I need. Does a swartz front for a H or M work, or do I need one for a newer model like the 560, or is there a specific front for the 504? (I want the new style hubs with bolt on rims.)
David B
12-03-2004 15:11:32
 Re: Farmall 504 wide front. in reply to Kelly Mehling, 12-03-2004 14:52:55
The factory wide front would have the tie rods behind, not in front. We got a new swartz from our IH dealer, your's might know with one is right.
Hugh MacKay again
12-04-2004 16:59:32
 Re: Farmall 504 wide front. in reply to David B, 12-03-2004 15:11:32
David: What I forgot to mention, I think if you go the Scwartz route, it has to be a special order. I forget the particulars but something is different on 504 from all other Farmalls
Hugh MacKay
12-04-2004 16:52:17
David: TP is right, and what is not so obvious in the photo, that factory front end is very little if any heavier than a Super C or 200. I bought one of these with a farm, it had 1200 hours on it at the time. Every day I kept that tractor it made my old 300 look better.
TP from Central PA
12-03-2004 17:11:01
No, I think the 504's had them in front. I'd like to adapt a '06 wide front to my 504 because of the loader on it..... .....It is a Narrow front now.
David B
12-03-2004 19:11:06
 Re: Farmall 504 wide front. in reply to TP from Central PA, 12-03-2004 17:11:01
Wow, I"d never thought IH would have done that. WHy would they have done that?
Allan in NE
12-03-2004 18:43:50
TP,
I was all set to argue with ya, but looks like you're right and this one is a rather late '67 too. I'll be darned.
Allan
third party image
