Super M Wiring
W6Tractor
12-03-2004 15:15:00
This post is for Bob Melville or anyone else who can help. I have a 1953 Super M with factory LP. It has a 12 volt generator (not original) and a ballast resistor in line on the wire from the positive side of the coil. Most of the other wiring is gone or in such disrepair that I can't be sure where everything was supposed to go. Additionally, I believe the original on/off switch has been bypassed as there is an aftermarket switch with a wire running to the starter switch. Should the wiring be the same as for stock M super M except add the resistor since the generator is now 12 volt? Thanks in advance.
Bob M
12-03-2004 15:51:54
 Re: Super M Wiring in reply to W6Tractor, 12-03-2004 15:15:00
I believe the wiring is the same on for LP tractor as it is for gasoline, though I cannot swear to it. Only difference I've seen on LPG powered tractors is some have a solenoid valve in the fuel line to the LP carburetor. The solenoid is wired to the switched side of the ignition switch so it cuts off the fuel when the ignition is off.
Surely there' s others on the board here with first hand experience and can provide a more positive answer!
w6tractor
12-05-2004 13:42:20
 Re: Super M Wiring in reply to Bob M, 12-03-2004 15:51:54
Thanks, Bob. Sorry for the delayed reply. I was waiting for additional posts. I guess my real question was about the ballast resistor. I assume it's still needed with the 12v generator. Does it just go in line from the coil and all other wiring remains the same as your stock 6v diagram? Thanks again.
