LOADER ON M
MARSHALL
12-06-2004 08:48:52
I HAVE A M WITH A M&W LIVE PUMP. I PUT ON A KELLY LOADER WITH ONE WAY CYLINDERS. THE TROUBLE IS I CAN'T GET THE AIR OUT OF THE CYLINDERS AND IT MOVES VERY SLOW. ANY SUGGESTIONS?
Diesel Don
12-06-2004 13:38:04
 Re: LOADER ON M in reply to MARSHALL, 12-06-2004 08:48:52
Raise the loader and crack the hose fittings at the cylinders until you get clear oil out of each side. That ought to take care of your problem. The loader still may seem a bit slow, but I don't know what flow rate/pressure the hydraulic system operates at. The system flow rate determines actual operating speed of a cylinder.
dej(JED)
12-06-2004 09:51:41
The loader has to have vent ends somewhere. Look for plugs on the other end of the cylinders and open them up. If the cylinders don't leak leave them open. The pressure from the up has to go somewhere.
MARSHALL
12-06-2004 10:26:51
 Re: LOADER ON M in reply to dej(JED), 12-06-2004 09:51:41
NEVER THOUGHT OF THAT BUT IT MAKES SENSE. I'LL CHECK TONIGHT. THANKS
