Adding Grease Fittings??
Paul_NJ
12-06-2004 13:11:30
Does anyone have any experience adding Zerk fittings to drag link ends?
In the process of removing the front axle of my 340 Utility, I removed the drag link power steering arms. The tie rod ends (connected to axle end) were really worn, so I found NAPA replacements for them. The other ends (connected to power steering) seem to not be badly worn, but one was really dry, and the other almost frozen due (I presume) to hardened grease inside the housing. Neither have grease fittings.
I could try to find IH replacements, but I imagine they would be pretty expensive. The old ones don't seem that bad, but need lubrication. Could I soak the old ones in kerosene to get the old (factory) grease solubilized, and then drill and tap holes to install a Zerk fitting? Is it better to go in the back plate, or the side (casting)? Seems reasonable, but I've never tried it before.
Thanks
Nebraska Cowman
12-06-2004 15:21:11
 Re: Adding Grease Fittings?? in reply to Paul_NJ, 12-06-2004 13:11:30
Its worth a try. If the are dry and stiff they ain't no good the way they are.
Novel Idea Guy
12-06-2004 13:14:39
The issue you're going to run into is drill shavings inside the ball joint from when you break through. Suspended in grease, they may not do any more harm than no grease at all, though.
Andy Martin
12-06-2004 15:25:37
 Re: Adding Grease Fittings?? in reply to Novel Idea Guy, 12-06-2004 13:14:39
A help with the drill cuttings is to drill (and tap) up from the bottom. You'll get cuttings on your face (shield) but they hardly ever fall up. Then flush with WD-40, etc. to get rid of what you can.
I would drill and tap prior to cleaning the rest of the joint.
