350 internatinal utility gd193
Vyron Mayle
12-06-2004 18:10:56
Can any one tell me where to get parts or if there is another engine that will interchange with it. Thanks, pokijoe
Redrider
12-07-2004 19:49:05
 Re: 350 internatinal utility gd193 in reply to Vyron Mayle, 12-06-2004 18:10:56
Vyron, you will have to stick with a 300/350 Utility engine as the front of the block is different than the Farmall blocks.
Ibby
12-07-2004 03:32:32
I believe the engine from a 300 or an H will interchange. Most parts are available pretty much everywhere.
Unreserved dick
12-07-2004 19:19:30
 Re: 350 internatinal utility gd193 in reply to Ibby, 12-07-2004 03:32:32
Mounting an engine from one of the Farmall models may be a problem (this would be from any of the H, Super H, Farmall 300, or Farmall 350 models) since they used the side rails for mounting. If I recall, he'd have to retain the front cover from the present engine to use with the new one, and he might have problems in the rear as well.
