counter rotating balancer
ian Davies
12-07-2004 02:43:21
I have an international 674, i forgot to match mark the counter rotating balancer gears with the crankshaft gear when I removed it I see a small center punch mark next to one of the teeth on the crankshaft gears but there is no mark on the smaller counter rotating gears how do i line them up with the crankshaft gear
Ian Davies
12-07-2004 19:11:05
 Re: counter rotating balancer in reply to ian Davies , 12-07-2004 02:43:21
Well I still dont know how to do it there seem to be no marks, owell guess ill just slap it back together and hope it doesnt shake to much
RAS
12-07-2004 10:02:47
Put the engine on #2 tdc and look you will see a mark on the gear on the engine and two marks on the balancer.
El Toro
12-07-2004 06:36:14
Call your local IH dealer and see if they will fax or mail you a copy of the counterbalancing gears on that 674 that is displayed in their shop
manual. They should have a picture that shows how
to mate thse gears. Hal
JLE
12-07-2004 04:14:56
There is a mark of some kind, I can't think what or where it is, it is in manual, and has to be timed!!!. I can't check mine today (manual). But if you still need info Wed. E-mail me.
