Re: 504 Background Info Wanted
Nebraska Cowman
12-07-2004 04:37:27
i hate to burst your bubble Bill but a 504 is a souped up C
Stan(VA).
12-07-2004 17:50:21
 Re: 504 Background Info Wanted in reply to Nebraska Cowman, 12-07-2004 04:37:27
The 404 is the souped up C, the 330/340/504 is a hybrid 350/460 rear with an engine from the Super C/2x0 family.
Stan(VA).
Hugh MacKay
12-07-2004 14:17:17
 Re: 504 to Cowman, Sloroll, TP in reply to Nebraska Cowman, 12-07-2004 04:37:27
Guys I don't think 504 was a bad idea on the part of IH. I lived in dairy country and in the days of 00 and 30-50, I always believed there should have been a live pto tractor in between 200 and 300, 230 and 350. First we saw the 330 utility. Later when the 40-60 series came along 340 filled the bill.
Then we went to 04-06 series. I think 504 diesel was great, they should have put the heavier front end like 300 and 350 under it though. I think by then 404 should have been engineered for live pto. The 504 gas engine has always annoyed me.
I bought my 504 gas in the purchase of a farm, I had every intention of keeping it. At the time I bought the farm, 504 was at the IH dealer for an engine rebuild at 1,200 hours. The vendor was having that done, so I was getting a tractor with a newly rebuilt engine. Dealer delivered 504 just as we were about to begin haylage. I put the 504 right onto the 9' NH Haybine. Vendor wanted to operate a bit to be sure rebuild suited him. Little did he know, he had just landed a two week job. At the end of two weeks he said to me, " Hugh if I were you I wouldn't keep that tractor too long. When new it didn't measure up to my expectations, and it still doesn't." Here I was with SA, 130, 300, 504, 656D and 560D. I had every intention of trading my old 300 on a new 1066. 1066 had been ordered and price agreed on trading 300. Decided I best see for myself about this 504. I took a No. 60 3x16 plow as well as 300 and 504 to the field. I plowed with each tractor for about 2 hours. Clearly the old 300 was all over the 504, and that 300 had 15,000 hours of history in 1975, and close to 3,000 hours on current pistons and sleeves. A few days later I approached the IH dealer about changing our agreed trade. He was delighted by the move, getting a more modern tractor with 3 point hitch, power steering, etc. My trade price dropped by $3,000. Was I right in making that move? I think I was. I watched that 504 after that time. It regularly came back to dealer about every two years, traded off on something. It was the only 504 gas he ever sold, and said he wished he'd never seen it. He sold numerous 504 diesels, and people were quite happy with them.
Hugh MacKay
12-07-2004 05:14:37
Cowman: I think you are being rather generous with the souped up C idea. While the rear chassis is 300, 350, 460, the front end is little heavier than C, SC or 200. The gas engine is a disaster, not quite sure how they ever came up with 46 hp, as they will not hold a candle to a 300 or 350 in the field. I rather doubt the diesel will measure up to the M, SM, 400 or 450. On the long haul you just can't ignor those extra cubes.
Think about it; 300-169 cu in, 350-175 cu in, 460-236 cu in and M through 450 all above 248 cu in gas and diesel. 504 gas 153 cu in, diesel 188 cu in. No my friends you just can't get long term reliable power from high rpm's, it's got to come from cubic inches.
Just about every manufacturer has tried the high rpm route and most have been failures.
TP from Central PA
12-07-2004 09:17:32
 Re: 504 Background Info Wanted in reply to Hugh MacKay, 12-07-2004 05:14:37
We had a stock "M"(248) at the same time as the 504..... ....I know that the 504 would run with the "M". IMO a stock "M" is nothing to brag about. A 300 will run over one.
It just didn"t have the stroke like the 169 in the 300..... ..
Sloroll
12-07-2004 05:39:07
Well I do have a super C and the 504 will pull it out of its shoes. I have had an H too and find it much more akin to it. To be fair to the fellow asking the 504 question I still think I am correct comparing it (work wise) to a Super H with a TA I didn't go so far as the 300 although probably similar to my 300U... Turning up a small engine doesn't allow for the grunt lugging power of large displacement engines. It does not have an abundance of torque. Because of the size and styling it is easy to over estimate the 504 I think it is a nice tractor as long as you use it for the nitch machine it is. One more point on the 504 the hydrolics are noisy and it takes awhile to get used to that.
Nebraska Cowman
12-07-2004 05:17:15
just thinking from the engine size. the 504 used a C engine bored out. Right?
Mike S 806/H
12-07-2004 14:45:32
 Re: 504 Background Info Wanted in reply to Nebraska Cowman, 12-07-2004 05:17:15
The 504 has the same bore and stroke as a Farmall H but alot more rpm"s. Power comes from the rpm"s and gear the pto down to get 46 hp. I have a 504 engine in a C and BN the BN on the dyno did 28hp but the pto was turning 950,
Hugh MacKay
12-07-2004 05:30:10
Cowman: Right.
Sloroll
12-07-2004 04:42:49
That'd explain a lot! : ?)
Nebraska Cowman
12-07-2004 05:14:55
 Re: 504 Background Info Wanted in reply to Sloroll, 12-07-2004 04:42:49
the 504 was supposed to do the work of an M and in some ways it did. When I was 10 years old dad bought a D15 Allis to replace the aging WD. Well the D15 did have more horsepower and we could pull 3 plows with it but it never was a WD. The WD became the D17 and the D15 was a souped up CA. And no, it didn't last. Lots of WDs still going and D15s in the junk.
