WD-9 Fuel Filter
WD-9
12-07-2004 17:35:02
I am searching for a fuel filter for my WD-9, the AUXILLIARY one to be specific. My local dealer was able to get the final filter but not this auxilliary one, it looks like yarn/cotton wrapped around a permaiable tube?
I'm also looking for a seat assembly and a swinging drawbar.
Any help would be greatly appreciated, thanks for your time.
David Manring
12-08-2004 05:05:41
 Re: WD-9 Fuel Filter in reply to WD-9, 12-07-2004 17:35:02
So what are the wix #'s for a MD or WD6 oil and fuel? They are not the same are they?
Bob
12-08-2004 06:05:49
 Re: WD-9 Fuel Filter in reply to David Manring, 12-08-2004 05:05:41
I believe the fuel filters will be the same.
MD, and WD-6 oil filters are #51125.
fishinmex
12-07-2004 19:13:30
These pople have both filters.
Carter & Gruenewald Co Inc cngcoinc@mailbag.com
3062832R91..... .....oil filter....$ 8.50
62946DA..... ..... ...fuel filter....$ 9.50
259479R92..... ..... fuel filter....$ 16
If you need to order these, please fax us at 608-455-1815 or call us toll free at 1-866-327-6255 98-5 cst)
Bob
12-07-2004 19:22:40
 Re: WD-9 Fuel Filter in reply to fishinmex, 12-07-2004 19:13:30
That confirms what I posted.
62946DA crosses to WIX #33147
259479R92 crosses to WIX #33148
So, if you choose, you can get them locally at a NAPA-type place, or any WIX retailer.
Haas
12-07-2004 18:20:11
I'm assuming the WD-9 situation is like the MD. For the MD that second fuel filter is not available either. My dealer told me to use the same filter in both housings so that is what I did and have not had any problems. Also the filter that was in there was the same in both.
Bob
12-07-2004 17:49:09
For a WD-9, WIX shows #33147, 16 micron,
and ..... ..... ..... #33148, 10 micron
The Wix catalog lists the 33147 16 micron filter as the secondary filter, and the 33148 10 micron filter as the primary filter, but I wonder if they could have the numbers transposed?
The 33147 is 6.344" high, 3.278" O.D., with an I.D. of 1.031".
The 33148 is 6.681" high, 3.372 O.D., with an I.D. at the top of .553", and an I.D. at the bottom of 1.341".
Do you have your old filter to compare these dimensions to?
