12 V batt in M
dvtw
12-07-2004 19:22:33
A day or so ago, someone was talking about a 12 V battery in an M Farmall. Forgive my ignorance, but can a 12 V battery be dropped in a 6 V setup on an M and everything be operable? Is there anything that needs to be done to prevent it from frying anything. Can someone educate me? I may just need to get an M from an old barn to my house. The old 6 V battery is DEAD. Would using a 12 V or 6 V be the way to go?
Thanks!
souNdguy
12-08-2004 17:43:38
 Re: 12 V batt in M in reply to dvtw, 12-07-2004 19:22:33
Either use a 12v dropping resistor or a real 12v coil.. like tsc has for the IH tractors.. or a napa ic14sb.
Over ont he N forum, we use a a8n10306 dropping resistor when we use a 6v coil and 12v battery to keep the coil and points happy.
Light bulbs would be the next issue., then the charging system.
Soundguy
F-Dean
12-08-2004 11:52:27
With kudos to JIG JOHN and Bob Melville, I offer the following based on my recent expereiences:
BIG JOHN has been putting a Hitachi #14231 alternator on several tractors in place of a generator under the hood. This alternator was used on 1978-79 Nissan 620 pickup with a 2 liter engine and a 1980 Nissan 720 pickup with a 2 liter engine. At NAPA it is part #2138130. The cost of a rebuilt alternator is approximately $50 + core (And they won’t take a generator as a core). The alternator is 4 1/2" in diameter and 7" in length and will go right on the original mountings on the tractor. Use an 8" x 3/8" bolt and some pipe for spacers. Being Hitachi means that it is METRIC. You will need to drill out the mountings to 3/8". The tension adjusting bolt is also metric thread. The alternator is a three (3) wire set up which can be converted to one (1) wire. There are spade connections labeled S & L and a BAT post connection. The L spade is for the idiot light and can be disregarded. Use a jumper wire from the S spade to the BAT post and you are good to go. The pulley is a split type that you can widen using a spacer (once again metric). You will need to use a disc type lock washer and some “Locktite” because there won't be room to reuse the split lock washer that comes with it. I was able to put the washer between the two pieces of the pulley to make it wide enough for my existing belt. There is a built in regulator and a resister to keep the battery from feeding back to the alternator. This is a sweet fit under the hood that he has used on H's, M's and W models, also Cubs and many others. I add the following from my experience:
Be sure to switch the polarity of the battery to Negative ground to avoid damaging the alternator.
Consequently, you need to switch the wires on the coil, if you are using a coil.
Use a plastic covered connection when you connect the jumper wire from the S spade
On a Farmall M, turning the bracket upside-down will allow the alternator to fit nicely inside the hood using the existing generator belt.
Nebraska Cowman
12-08-2004 04:51:02
just a short trip, nahh, you can't hurt a thing. If you still have a magneto ignition you can run it that way forever. If you have distibutor ignition you will need to add a resisotr to the coil to keep from burning up points. Of course a 6 volt generator won't keep up but you can put the battery on a charger once in a while.
Bubba
12-08-2004 04:07:28
I have been working on my 12V system on my M too. I rewired my system yesterday. To your question, I put an 8V battery on my H which was still an 6V system and didn't have any problems; however, I don't know if you can still buy an 8V battery.
farmallhal
12-08-2004 06:42:09
 Re: 12 V batt in M in reply to Bubba, 12-08-2004 04:07:28
Saw a brand new 8 volt one the other day at our local farm and home center here in central Missouri. Was told they stock them just for that purpose. Was something around $50.00.
El Toro
12-08-2004 17:50:27
 Re: 12 V batt in M in reply to farmallhal, 12-08-2004 06:42:09
Hi Farmallhal, Who was the manufacturer of that
8 volt battery that you saw? Hal
gusc
12-07-2004 19:49:50
Try connecting the 12v battery directly to the starter. If it starts, quickly disconnect the 12v. If it keeps running, take it to the house.
You can't leave the 12v hooked up with the 6v generator. If you run the engine with 12v you need a ballast resistor on the switch lead to the coil.
BIG JOHN
12-07-2004 19:34:03
Go to the left side of this page. Scrol down to "
Researh & Info", click on "Articles" and then go to "12 Volt" This will bring up more info than you can read in one night.
GOOD LUCK
