Super A Carb
Shaggy
12-07-2004 21:29:56
The Carb that I have on my Super A is a carter UT and I really don't like the way it runs. It smoke (black) when you 1st start warm or cold choke or no choke and when you snap the throttle it stumbles then take off. I have checked the float level and it good and it has no vaccumn leaks either. Would a Marvel or a Zenith be a better Carb? Thanks Shaggy
Slappy
12-08-2004 03:12:37
 Re: Super A Carb in reply to Shaggy, 12-07-2004 21:29:56
Shaggy,
I swapped the Carter carb on my SA for a Zenith and believe that I like it better. I couldn't stop the Carter from leaking even with a new seat and needle.
retired
12-08-2004 10:34:45
 Re: Super A Carb in reply to Slappy, 12-08-2004 03:12:37
Spring for a new Zenith, finally gave up on my Carter even after several attempts to overhaul, just could not stop the leaking. Still had to adjust the float in the new Zenith.
Shaggy
12-08-2004 22:00:26
 Re: Super A Carb in reply to retired, 12-08-2004 10:34:45
I have a Marvel in the Carb cleaner now and the Kit is about $15 give or take. The Zenith on my B is great! and the Marvel on Dads is good too. Whats up with the Carters?
